SCRIPAL Posted October 22, 2017 Share Posted October 22, 2017 The fresh water tank valve on my 89 Dolphin is very difficult to turn on and off and needs to be replaced. Is the 3/8" valve the correct size for the water line? Any help appreciated. Quote Link to comment Share on other sites More sharing options...
jmowrey Posted October 22, 2017 Share Posted October 22, 2017 The valve on my 85 Dolphin was very hard to turn when we first got it. I spray a little WD-40 on it now and then, open and close it a few times to work it in, and that makes a big difference. Quote Link to comment Share on other sites More sharing options...
SCRIPAL Posted October 22, 2017 Author Share Posted October 22, 2017 Thanks, will get her a try. Quote Link to comment Share on other sites More sharing options...
Homer Posted October 22, 2017 Share Posted October 22, 2017 If you are talking about the drain valve that has a tube sticking below the floor, Mine kept getting so hard to turn to drain even with channel lock pliers. I unscrewed the strap that held the tank in place in front and put a wedge 2x4 (like a doorstop) under it and raised it up enough to unscrew the drain valve. When I got it removed there were plastic slivers embedded in the drain hole like where they drilled the tank to put the fittings in. I took the inlet hose off and put a small vacuum hose down in the tank and more slivers got sucked up . After that I really flushed the tank out with a water hose . (What a crock to have to do because of others [ tank builder] neglect). I ordered a new one from ebay, installed it and have had no problem since. Hope you solve your dismay. Quote Link to comment Share on other sites More sharing options...
markwilliam1 Posted October 23, 2017 Share Posted October 23, 2017 Hi Al! I only use the on board pump to drain my fresh water tank. The fear of fooling around with valves that are over 25 years old and they suddenly develops a leak after you attempt to use them again isn’t far from my mind! Good Luck! Quote Link to comment Share on other sites More sharing options...
SCRIPAL Posted October 23, 2017 Author Share Posted October 23, 2017 Used the lubricant JMOWERY suggested and it works great! Quote Link to comment Share on other sites More sharing options...
