I recently swapped 4.10 gears for 4.88 gears. Very pleased with the result. Next step is to swap in a manual for the current automatic. Got a couple of questions. First which manual did you install and why? Were you happy with the manual that you installed and if not why? Plus any suggestions on friction disk pressure plate would be appreciated.
Thanks
