256bit Posted September 1, 2017 Share Posted September 1, 2017 Because I have the 1 ton axle I'm not sure if the FSM 1/2 ton info is relevant. When I was checking the ujoints due to clunking when shifting, I discovered that I have half an inch of play in my propeller shaft. Anyone know what the maximum spec on the play is? That's probably where all my annoying driveline slack is. I'm thinking the clunking while shifting delio is a worn out rear transmission mount because the shifter pulls really hard to one side if I dump the clutch in first. Quote Link to comment Share on other sites More sharing options...
WME Posted September 1, 2017 Share Posted September 1, 2017 Movement front to back or side side? Quote Link to comment Share on other sites More sharing options...
Maineah Posted September 1, 2017 Share Posted September 1, 2017 Sounds fairly normal to me for a 34 year old truck. Ring to pinion play and old engine mounts. Quote Link to comment Share on other sites More sharing options...
256bit Posted September 2, 2017 Author Share Posted September 2, 2017 (edited) On 09/01/2017 at 0:16 AM, WME said: Movement front to back or side side? 1/2" rotational play, should have specified. Side to side maybe 1/16. I haven't properly checked front to back by jacking the transmission but otherwise none. 23 hours ago, Maineah said: Sounds fairly normal to me for a 34 year old truck. Ring to pinion play and old engine mounts. Yeah I figure the pinion is too far forward or the ring gear is too far to the side, but I definitely don't know what the hell I'm doing and can't reshim the bearings. The differential is frightening since it's the only part of the driveline that can't be DIY'd and I'm too broke for a gear shop Mostly just needing to know (hoping) the diff isn't going to grenade itself anytime soon. Picking up that slack can't be good for the gears. Edited September 2, 2017 by 256bit Quote Link to comment Share on other sites More sharing options...
