Cedric lauzon Posted August 20, 2017 Share Posted August 20, 2017 Hey fellows toyoters . New to the forum and trying my first post ! My 1991 itstaca spirit has been leaking power steering fluid for the last 5000 miles and it is getting worst !!!! it started leaking a little on the passenger side and now it also on the driver side and with the fix leak bottles from Walmart it did not even slow down the leaking . So now I have a place to work on it for a couple of weeks and I look at all these oily parts and don t even know where to start !!!!! kind of like a panic attack ! But , I know there is a solution for everything , Any of you good souls could put me on the right track ....?.....Cannot afford the mechanic. Got to do it myself !!! Thank you . r Quote Link to comment Share on other sites More sharing options...
Derek up North Posted August 20, 2017 Share Posted August 20, 2017 Clean everything in the area with a pressure washer and brake cleaner. Start the engine and look for leaks. Quote Link to comment Share on other sites More sharing options...
Cedric lauzon Posted August 20, 2017 Author Share Posted August 20, 2017 Merci beaucoup !, Brake cleaner only car je n aie pas de pressure washer ,ca devrait marcher ?! Vive le Quebec! et les Québécois! Quote Link to comment Share on other sites More sharing options...
Maineah Posted August 20, 2017 Share Posted August 20, 2017 Two common places idle kick valve and sector shaft seal. Quote Link to comment Share on other sites More sharing options...
Cedric lauzon Posted August 21, 2017 Author Share Posted August 21, 2017 Thanks man ,will check ,can you specified idle kick valve .and shaft seal , o ring ? Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted August 21, 2017 Share Posted August 21, 2017 there is not much to a power steering circuit. Clean it up and start looking. Attached is a pdf of the service manual section on PS p1422-2455.pdf Quote Link to comment Share on other sites More sharing options...
Cedric lauzon Posted August 24, 2017 Author Share Posted August 24, 2017 Thank you so much . will study it ,and start the project this week end . Quote Link to comment Share on other sites More sharing options...
