jhdbad Posted July 17, 2017 Share Posted July 17, 2017 Sorry to revisit this topic but search resulted with so many results. What would you recommend tire pressure and airbag pressure for an 18 ft Sunrader with Yokohama load D? Thank you Quote Link to comment Share on other sites More sharing options...
Derek up North Posted July 17, 2017 Share Posted July 17, 2017 Yes, been asked many times and there won't be consensus this time here either. Try 50psi and start playing. Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted July 19, 2017 Share Posted July 19, 2017 Not familiar with your particular toy, but since most of these are running around overweight, I would go with the max psi stamped on sidewall. Quote Link to comment Share on other sites More sharing options...
jhdbad Posted July 19, 2017 Author Share Posted July 19, 2017 Thank you I ask because the ride has been real stiff in the back with each bump in the road magnified ... would adjusting inflation of airbags and tires have any effect on this stiffness? Quote Link to comment Share on other sites More sharing options...
Derek up North Posted July 19, 2017 Share Posted July 19, 2017 Yes, adjusting tire and air spring pressures will affect the ride. What pressures do you have now? Quote Link to comment Share on other sites More sharing options...
jjrbus Posted July 20, 2017 Share Posted July 20, 2017 When I got my Toy it desperately needed new tires. Some here said use 65 psi in the tires. Without putting any thought into it or doing any due diligence I put in 65 psi. Thought I was going to jar my teeth loose. Every bump in the road shook and rattled the whole coach. Quite appropriately described as riding on bowling balls on another forum. Don't know anything about your Toy so would not even hazard a guess as to what pressure should be. Air springs take a bit of experimenting, they are great for isolating vibration and shocks. First the bags should be inflated to level the coach front to rear and then side to side, one side may have more pressure than the other to level side to side. 50 psi is a good starting point for most, you may need more or less. Too little pressure and you will have sway, too much will result in a stiff ride. Without checking I think I have 60 in one side and 65 in the other or could be 50 and 55?? Quote Link to comment Share on other sites More sharing options...
256bit Posted July 30, 2017 Share Posted July 30, 2017 (edited) I'm not an expert but I'd say check your shocks and airbags. My sunrader ('83, no airbags) had the same issue, and I when I replaced the shocks, I discovered that the 2 front shocks had completely leaked their hydraulic fluid, meaning that I essentially had no front shocks. I didn't even have rear shocks installed, and I need to have my leaf springs restored. These things are kind of a rough ride but it shouldn't feel like you're rolling on bowling balls. Check over your suspension. Edited July 30, 2017 by 256bit Quote Link to comment Share on other sites More sharing options...
