redskinman Posted June 8, 2017 Share Posted June 8, 2017 I did a search on here for Zep but came up with nothing. Who has used Zep and what was the process you did? Thanks Quote Link to comment Share on other sites More sharing options...
Bikemike Posted June 8, 2017 Share Posted June 8, 2017 I got a gallon at Home Depot and put it on with a small rag. Several thin coats (4-5 maybe). A little goes a long way. Make sure you clean the camper Really, Really well. Anything you don't get off will be sealed in! Quote Link to comment Share on other sites More sharing options...
Bikemike Posted June 8, 2017 Share Posted June 8, 2017 It's called "wet look" floor polish or something like that. About $25 a gallon. Quote Link to comment Share on other sites More sharing options...
WME Posted June 8, 2017 Share Posted June 8, 2017 (edited) Used an air powered jitter bug sander with wet&dry paper (wet), to clean and remove fuzzies. I used 600-1200 grit paper depending on how bad things were. 5 coats with 6 on the front. First coats look bad, just keep going 1 year old , WY winter, looks good Edited June 8, 2017 by WME Quote Link to comment Share on other sites More sharing options...
redskinman Posted June 8, 2017 Author Share Posted June 8, 2017 23 minutes ago, WME said: Used an air powered jitter bug sander with wet&dry paper (wet), to clean and remove fuzzies. I used 600-1200 grit paper depending on how bad things were. 5 coats with 6 on the front. First coats look bad, just keep going 1 year old , WY winter, looks good What fuzzies? Before putting it on or after putting it on you had fuzzies? Quote Link to comment Share on other sites More sharing options...
Derek up North Posted June 8, 2017 Share Posted June 8, 2017 I'm puzzled as to why it doesn't show up with a Search, but it's come up before. As mentioned above (and like a paint job), preparation is the key. Any blemishes will be sealed in but not hidden. Quote Link to comment Share on other sites More sharing options...
WME Posted June 8, 2017 Share Posted June 8, 2017 Fuzzies were the old naked siding and fiberglass panels Quote Link to comment Share on other sites More sharing options...
markwilliam1 Posted June 8, 2017 Share Posted June 8, 2017 I posted the entire process with pictures when I Zepped Grannie last year. Should be able to find it under my posts. As others have said surface prep is the key! If you apply the Zep over Any imperfections it will be sealed under the Zep. Applying the Zep is the easy part. Surface prep is the hard part! Good Luck! Quote Link to comment Share on other sites More sharing options...
Derek up North Posted June 8, 2017 Share Posted June 8, 2017 80% elbow grease, 20% ZEP. Quote Link to comment Share on other sites More sharing options...
redskinman Posted June 8, 2017 Author Share Posted June 8, 2017 1 hour ago, Derek up North said: I'm puzzled as to why it doesn't show up with a Search, but it's come up before. As mentioned above (and like a paint job), preparation is the key. Any blemishes will be sealed in but not hidden. Me too,did you try it? I dont know what other word to search for than just putting in Zep,maybe Led Zep? Quote Link to comment Share on other sites More sharing options...
jjrbus Posted June 8, 2017 Share Posted June 8, 2017 I went and got the 12 year old next door! http://toyotamotorhome.org/forums/index.php?/topic/9505-the-magic-of-zep-wet-look-floor-polish/ Quote Link to comment Share on other sites More sharing options...
redskinman Posted June 8, 2017 Author Share Posted June 8, 2017 (edited) 51 minutes ago, markwilliam1 said: I posted the entire process with pictures when I Zepped Grannie last year. Should be able to find it under my posts. As others have said surface prep is the key! If you apply the Zep over Any imperfections it will be sealed under the Zep. Applying the Zep is the easy part. Surface prep is the hard part! Good Luck! I see your siding is different then mine,do you think it will help mine? Edited June 8, 2017 by redskinman Quote Link to comment Share on other sites More sharing options...
markwilliam1 Posted June 8, 2017 Share Posted June 8, 2017 Yes!! They are both fiberglass panels. Will work perfectly!! I would kindly dispute Derek. I say 90% elbow grease and 10% Zep. It was a bear to clean the old fiberglass. That's where Bar Keepers Friend (powder form) comes into play! Post pictures! Quote Link to comment Share on other sites More sharing options...
redskinman Posted June 8, 2017 Author Share Posted June 8, 2017 36 minutes ago, markwilliam1 said: Yes!! They are both fiberglass panels. Will work perfectly!! I would kindly dispute Derek. I say 90% elbow grease and 10% Zep. It was a bear to clean the old fiberglass. That's where Bar Keepers Friend (powder form) comes into play! Post pictures! I bought some of the bar keepers friend in the bottle. Quote Link to comment Share on other sites More sharing options...
linda s Posted June 8, 2017 Share Posted June 8, 2017 Marks corrugated fiberglass was known to get fiberglass threads sticking out if it and making it look fuzzy. Very hard to clean up. Your smooth panels will be much easier to clean before the Zep is applied. Linda S Quote Link to comment Share on other sites More sharing options...
markwilliam1 Posted June 8, 2017 Share Posted June 8, 2017 Linda is correct. My panels did have some uneven spots but no threads sticking out. I used the powder form as I think it has better abrasion properties than the liquid. The Zep sealed everything so well I can run my hand down the fiberglass and is smooth as silk now. You won't be disappointed red!! Quote Link to comment Share on other sites More sharing options...
redskinman Posted June 9, 2017 Author Share Posted June 9, 2017 Thanks for the help everyone.Started washing it tonight but it got dark before I finished.Luckily I dont have a lot of bad stains.I had 2 streaks coming down from the rear window that I was scrubbing and scrubbing with a sponge with the bar keepers friend and it was rough going,didnt want to come off.I had some spray cleaner I bought at the dollar store called "Awesome" that I sprayed on the streaks and it took it right off,not impressed with the bar cleaners friend,powder form might work better but the Awesome spray was awesome Quote Link to comment Share on other sites More sharing options...
linda s Posted June 9, 2017 Share Posted June 9, 2017 Another help with cleaning hard spots. Mr Clean magic eraser. I buy the cheap dollar store ones. Get any spots off really good but they do fall apart quickly. Linda S Quote Link to comment Share on other sites More sharing options...
SCRIPAL Posted June 9, 2017 Share Posted June 9, 2017 Mark, again you did a great job on the Granville and it looks fantastic. Quote Link to comment Share on other sites More sharing options...
markwilliam1 Posted June 9, 2017 Share Posted June 9, 2017 (edited) Thanks Al that's important coming from you as you were my Mentor when I first got Grannie! Red I didn't use a sponge I used those green scrubbing pads. Went through a bunch of them! The powder form of BKF took off 30 plus years of grime, mildew and stains! Glad you found something that works. Also when applying the Zep I used those micro fiber cloths and as WME suggested put the wet cloth in a zipped lock bag to re-use it. I still get the occasional black streaks but just spray a little simple green and they wipe right off. Can't wait to see your completed rig! Your gunna be in shock! PS, make sure you have absolutely No Residue of any cleaning products on the surface before applying the Zep. That's where the TSP comes in. Surface must be squeaky clean! Edited June 9, 2017 by markwilliam1 more info Quote Link to comment Share on other sites More sharing options...
cliffhanger4 Posted June 9, 2017 Share Posted June 9, 2017 (edited) is this the stuff you are using Edited June 9, 2017 by cliffhanger4 Quote Link to comment Share on other sites More sharing options...
markwilliam1 Posted June 9, 2017 Share Posted June 9, 2017 Yep! That's it cliff. I recommend 5 coats. Quote Link to comment Share on other sites More sharing options...
redskinman Posted June 9, 2017 Author Share Posted June 9, 2017 2 hours ago, markwilliam1 said: Thanks Al that's important coming from you as you were my Mentor when I first got Grannie! Red I didn't use a sponge I used those green scrubbing pads. Went through a bunch of them! The powder form of BKF took off 30 plus years of grime, mildew and stains! Glad you found something that works. Also when applying the Zep I used those micro fiber cloths and as WME suggested put the wet cloth in a zipped lock bag to re-use it. I still get the occasional black streaks but just spray a little simple green and they wipe right off. Can't wait to see your completed rig! Your gunna be in shock! PS, make sure you have absolutely No Residue of any cleaning products on the surface before applying the Zep. That's where the TSP comes in. Surface must be squeaky clean! Whats TSP? I was using a sponge but it was one with the soft surface on one side and the hard scrubber on the other side and I was using the hard side. I was going to use a sponge mop to apply it as seen in a youtube video. Is there any rinsing between coats? How long did you wait before applying another coat? thanks Quote Link to comment Share on other sites More sharing options...
Derek up North Posted June 9, 2017 Share Posted June 9, 2017 55 minutes ago, redskinman said: Whats TSP? https://en.wikipedia.org/wiki/Trisodium_phosphate Quote Link to comment Share on other sites More sharing options...
redskinman Posted June 9, 2017 Author Share Posted June 9, 2017 30 minutes ago, Derek up North said: https://en.wikipedia.org/wiki/Trisodium_phosphate Is this in a product I can buy? Quote Link to comment Share on other sites More sharing options...
markwilliam1 Posted June 9, 2017 Share Posted June 9, 2017 Yes that's what I used very diluted! I wouldn't recommend a sponge mop. You'd have excess Zep dripping down everywhere! It goes on like water and you don't want drips! Even thin coats. It dries very fast and you put on multiple thin coats. You can probably put on the 5 coats of Zep in 1 day. By the time you've Zepped your entire rig you can go back and start over. It will be completely dry. The first 2 coats will look pretty bad. Keep applying. The extra coats will seal each previous coat and you will see it starting to shine evenly. Will definitely last way more than 1 year if applied properly! Hope this helps. Quote Link to comment Share on other sites More sharing options...
redskinman Posted June 11, 2017 Author Share Posted June 11, 2017 In the middle of this project now,taking a break.Heres some before pic,dont know how well we will be able to tell how good it will look after with it being white but we'll see. Quote Link to comment Share on other sites More sharing options...
redskinman Posted June 11, 2017 Author Share Posted June 11, 2017 Ive only done front cab and rear of coach so far,but I think you can see a difference in the front of coach and the side that I havent done. Quote Link to comment Share on other sites More sharing options...
redskinman Posted June 11, 2017 Author Share Posted June 11, 2017 Finished product,I can definitely tell a difference,thanks everyone. Quote Link to comment Share on other sites More sharing options...
WME Posted June 11, 2017 Share Posted June 11, 2017 Yep looks good. I'm sure you asked yourself the same question I did, " why didn't somebody do this 20 years ago when the decals were fresh". Quote Link to comment Share on other sites More sharing options...
hunkaman Posted June 11, 2017 Share Posted June 11, 2017 LOOKS GREAT, WILL BE DOING MY RIG SOON. THANKS FOR SHARING. JOE FROM DOVER Quote Link to comment Share on other sites More sharing options...
markwilliam1 Posted June 12, 2017 Share Posted June 12, 2017 Beautiful job red!! You did it Perfectly Man!! Quote Link to comment Share on other sites More sharing options...
redskinman Posted June 12, 2017 Author Share Posted June 12, 2017 2 minutes ago, markwilliam1 said: Beautiful job red!! You did it Perfectly Man!! Thanks and thanks for the help Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted June 12, 2017 Share Posted June 12, 2017 curious, presumably "some day" will come when this stuff starts breaking down. How long will this application last and what will need to be done to strip and redo? Quote Link to comment Share on other sites More sharing options...
markwilliam1 Posted June 12, 2017 Share Posted June 12, 2017 Not sure about that Dan! As I previously stated a guy sold his rig that he Zepped 7 years ago and he said it still looked new. I know it will way outlast the best wax available. Sun and heat would be a factor I'd assume. Zep also makes a wax removal product so I guess you could use this to remove the Zep wax and redo. Shouldn't be that hard and then you'd have a clean service to reapply the Zep. I truly feel you cannot go wrong with the Zep. Quote Link to comment Share on other sites More sharing options...
