TheGrayOutdoors Posted June 2, 2017 Share Posted June 2, 2017 Okay, Believe it or not, we didn't see the extent of this damage because it was so expertly covered up by the previous owner. I think that the old axle snapped at some point and the rear tire tore a hole in the floor, but who knows. When I started pulling back rotted wood it was a nightmare, but slowly it's been put back together and now I think stronger that ever. First I cut out all the bad. Then I cut a square of aluminum to which I riveted to the existing aluminum and sealed with dicor. Then I laminated in 1 x 3 crossmember using a kreg jig and screwed the aluminum into this. From there it was a cut and fit job with foam insulation and 3/8 inch ply. My wife went in with the fiberglass and built up the torn out wheel well and connected everything with mat and completely encapsulated the top side of the ply and the underside creating a complete bonded seal with the Aluminum. I sprayed the underside with Rustoleum undercoating and we primed and painted the interior white. Quote Link to comment Share on other sites More sharing options...
WME Posted June 2, 2017 Share Posted June 2, 2017 Looks good. In a millennium some archeologist will dig up that wheel well and spend the rest of his/her life expounding on what type of civilization created the sacred object. Quote Link to comment Share on other sites More sharing options...
markwilliam1 Posted June 3, 2017 Share Posted June 3, 2017 Beautiful repair job!! Quote Link to comment Share on other sites More sharing options...
hunkaman Posted June 3, 2017 Share Posted June 3, 2017 great work. i can tell that was not easily done. the finished repair will outlast everything else ! LOL. thanks for sharing. joe from dover. Quote Link to comment Share on other sites More sharing options...
