3Daves Posted May 26, 2017 Share Posted May 26, 2017 Just bought an '82 Odyssey with a 22R. Plugs were black upon inspecting engine, but otherwise the engine is very clean, with about 88K miles. New to this engine, so started doing research, which led to de-smogging the engine. Not yet running, still in the process of doing the up (down?) grade. I didn't like the idea of all of those fifty or so vacuum lines running everywhere as "single points of failure"; and I knew that they'd just make it impossible to troubleshoot under harsh conditions. I have nothing against emissions control, but I'm pretty sure that it's not working, and I wanted something easy to troubleshoot on the road. I kept the PCV valve, and would like to re-engage the EVAP, so that gas/vapors aren't vented into the atmosphere. If I can't, then that's ok, but would like to try. So, my questions: 1- Is there a way to keep the basic EVAP functionality, even if diminished, in this situation? (using the existing ECM module, or just hooking the EVAP system up passively, somehow). 2- Can I find a generic charcoal canister to replace the old one? 3- (and unrelated to eariler questions) How important is it to keep the air pump working? If disabled, will it ruin the catalytic converter? BTW, the new carb is a Weber 32/36; jetted for high altitude (7000'). Thanks! Quote Link to comment Share on other sites More sharing options...
WME Posted May 26, 2017 Share Posted May 26, 2017 Long read, but there pics... This guys sell conversion kits, more reading...http://www.lcengineering.com/LCTechPages/carbtech.html Quote Link to comment Share on other sites More sharing options...
